Whenever I try to use my new Sony headphones (WH-1000XM3) I have to go into the TVs settings and search for them, is this normal?
With other headphones all I have to do is switch them on and the TV asks if I want to use them.
Thanks for the reply. If I connect (pair) with a new device do I have to connect (pair) again with the other device?
I pair with my television and the headphones work, I then pair with my phone and they work. If I then go back to the television the headphones will not work unless I pair again. Is this correct?
The headphones should automatically connect to the last paired device if it's available. do they do the same thing with your phone for example?
Thank you for the help. Really appreciated.
