my tablet has random reboots, sometimes once a day sometimes 5 times a day and sometimes it also does have a display flickering. Does anybody have the same problem?... Do I have to send it to replace the unit?.... To get It fixed?... Asking Sony for an advice.
The rebooting issue could relate to an app you've added. Has the tablet always done it or is this something new.
I have this problem from the begginig. It should be not related to any app.
if you have this from the beginning on a clean system: contact sony support and sent it in for a replacement.
Rebooting: Something faulty on your motherboard.
Flickering: set brightness to 75 %, not 100% and disable Autobrightness, to see if it helps.
