Hello there! I wonder if anyone can help me. I bought an Sony tablet P last summer at USA and I can't find a way to use the internet at places that hasn't wirefire. I bought a modem and a chip to use this way, but there's no input slot of that size, because there's only an micro-USB entry, and the modem is USB. Is the any device to convert the micro-USB onto USB? Thank you in advance!
You have a sim card slot under the top cover of the tablet p. The cover slides open and you'll be able to see the slot.
I suggest you take a look at that chip and if it is a sim card 3g normal size then use it directly on the tablet.
Another way is to by a micro-usb to USB female cable. This would allow you to connect both devices, but I don't know if they are compatible to work like that.
Hope it helps.
Hope it helps.
