Can anybody help me find out how the P series tablet connects through 3G ? I cannot find any information anywhere as to whether the unit has a SIM card slot, or needs to be connected to an external dongle, and if so is it limited to certain dongle models, like most tablets, also cannot find information about memory expansion IE sdhc slot and what the maximum card size is.
Many thanks if you can help.
The Sim card is located under the top cover which slides forward to open. It's a full size Sim card.
As for the SD card I'm currently using a 32GB size. I think this is the max size you can get for this device however, I read recently on another forum that someone has used a 64gb size and it worked. This I haven't been able to test.
Hope this helps.:smileywink:
