HI there, I have a device sgp611, it has android 4.4.4 on it.
The problem is that there is no OTA updates available for me, not in the inbuilt update tool, nor if check by IDID number on the support site.
How I can install firmware with Android 6 on my tablet? And I mean guarantee install, not shaman dances with downloaded from 3Rd party sites firmwares.
Thanks.
the latest update build for this model seems to be 23.5.A.1.291..which is android 6.0
have you tried to connect to xperia companion?
Yes, I did - with the same result: no updates available
