Hi, I had issues previously with this keyboard. The battery would die within a few hours of use even though it was fully charged. I tried resetting the keyboard now using the instructions I found in the user manual. After that, the indicator light on the keyboard goes off then comes back on when I release the switches and stays a solid white. Now I can't switch the keyboard on or off and I also can't connect it to my tablet because the pair button and the on/off button seem to have no effect. If I try to plug in the charger, the light does not change and whenever I try to pair through bluetooth my tablet can't detect it. I have also tried the NFC and it fails to connect. What is the issue here? It seemed to arise when I reset the keyboard by holding the bluetooth button and pushing down the power button for a few seconds.
Hi @Kaz6
Welcome to the community!
Sorry to hear about that
The best thing to do would be to get in contact with your Local support so they can assist in getting the keyboard through to a service centre for assessment.
Good luck
Im having the same problem did you find out what the problem was please
Has anyone been able to find out the problem
