x
How do I close running apps?
SOLVED
profile.country.en_GB.title
Ankitv
Visitor
Hello All,
Yesterday I bought this tablet s from john lewis. I opened up quite a few apps and could view from that multi tasking panel but couldnt find a way to close each app. I went into setting and then selected manage appilications, but nothing happens.
Could you please guide?
1 ACCEPTED SOLUTION
Accepted Solutions
Ankitv
Visitor
got it. its in the settingS menu . I must be blind not to look at it the first  time around
2 REPLIES 2
Ankitv
Visitor
Watashiwateshdes
Contributor
As you have found, you can force close them.
Some will automatically close after a certain period of time if they are not run again and some instantly close when you exit so it will vary. Either way, I rarely force close apps and find there has been no lag or additional drain on battery.
There are task killers available but for Honeycomb, they are not really needed.
