- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
XNVL77BT
Can the XNVL77BT Chargethe Ipod?iphone?
Does the USBconnection allow video/ films to play on screen from the Iphone/Ipod?
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Yes it charges the Iphone so i guess it charges Ipod too
Regarding the film video it's yes if you have the right cable.
Regards
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Bear in mind the usb output is probably going to be 0.5Ah, and smartphones require 1Ah, you might find your phone draining faster than the charge, or on a very slow charge. It really may only be suitable for keeping the phone topped up.
I know with my Sony Head Unit 0.5Ah USB output I can slowly charge up (or maintain the charge) on my Dell Streak which normally requires 1Ah, but the Streak will not start on a flat battery when plugged into the USB. It tries to light up, but there is just not enough power on the USB to get it going.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hello
know if the (Sony XNV-L77T) has GREEK menu;
Thank you very much
