- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Why don`t the buttons on my Sony Walkman NWZ-E443 work.
When I press the play/pause button it skips to the next song and when I press the Back button it pauses the song. Also I can`t access the Home menu. Please help as it`s driving me mad!
Thanks in advance
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi hulynch,
All sounds a bit odd doesn't it? I would try a reset of the unit using the pin hole on the rear of the unit to start with. I also notice that there's a firmware update (v1.01) avaialble for the E443 on Sony's website, so if a reset doesn't solve the problem this might also be worth a go (the link to the firmware update is below):
http://support.sony-europe.com/dna/wm/nwvp/nwvp.aspx?site=odw_en_GB&m=NWZ-E443
Can't think of anything else worth trying, so if no joy from the above I would consider getting the unit checked out.
Hope this helps.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi there Drumzman, thanks for your reply but I have done everything that you said but it is still the same. I guess that I'll wait a day or two to see if anybody else has any suggestions and if not then I'll have to see about igetting it checked out at a Sony dealership.
Thanks again
