When using either set of headphones as soon as I receive any sort of Ring App notification on my Samsung phone, I get a huge blast of loud static sound lasting about 5-6 seconds
It happens on both sets of headphones and didn't happen with previous headphones, I bought the WFs to replace, I've recent reset the WH to factory settings due to other issues but it hasn't sorted this out.
Does anyone have any suggestions?
Hi @Kappa698
Did you try to test the app with the headsets on other devices and check if the same thing will happen or not?
