Having an issue with right earbud and severe battery drain.
It may reduce from fully charged to 20% (with low battery notification) within 1 hour of use. Left earbud would still show 80+%.
If I put back in case it may jump by 20% straight away. Something is not right.
I am on latest software and have reset both earbuds - but issue persists.
They are still within warranty but I wondered if anyone had experienced similar and may have suggestions before I request a replacement?!?
sounds like a battery issue? You better ask for a replacement unit
Hey @paulede75, are you getting this issue constantly with the right bud? If yes and you've initialized the headphones already and it still draining quickly, that seems to be a hardware issue I'm afraid 😞 Try reaching out to the Sony support reps directly to arrange a repair.
