Too low sound on my WF-1000XM4
Got these headphones a little under 6 months ago and I'm not happy at all. The volume is so low. I just can't believe how low it is for a €300+ earbud.
I had the WF-XB700 which are over two years old. Their bass and volume would rattle your teeth. The only downside is that they didn't have Sony Headphones Connect app support. Which is weird given they are made by Sony.
The sound out of the new ones are shockingly bad. I just cannot believe they're so bad for the price.
What can I do?!
I've turned off Bluetooth Absolute Volume.
I've disconnected bluetooth.
I've readded them into the headphones app.
I've changed earbud tips (the old ones from my WF-XB700).
I've tinkered with the EQ.
NOTHING seems to be working.
Have you tried to control the volume via the touch sensor?
Depending of the device you can set volume both on the device and earbud separately. Could be volume from device max but from earbud min.
