Hi guys,
I need help with this one.
How do I stop unauthorized connections to my Sony - SRS-XP700 Bluetooth speakers.
Some random stranger has connected to my speakers. Whenever I turn my speakers on, their music comes through.
Idduke
@idduke Try initializing the speakers or delete the paired devices, but to do a factory reset is better: https://helpguide.sony.net/speaker/srs-xp500/v1/en/contents/TP1000243122.html
Thank you TheGoat.
That did it. Pesky neighbour(s) and all.
idduke
