Every time I turn off the speaker by pressing the power button quickly so as not to reset pairing data it still won't reconnect automatically to previously paired sources.
So I have to re-pair every time I turn it on.
It is also updated to latest 4800 firmware
Anyone else had this problem and worked out a solution?
Many thanks for help!
Hey @dargassi, how many devices can be paired with the speaker? The speaker can be paired with up to 8 devices. If a new device is paired after 8 devices have already been paired, the earliest paired device will be replaced by the new device. If it's not the case, try initializing the speaker and check again
