I have bought a set of SONY WI-C100 headphones. However, there is no charging cable or anything similar in the box. So, how do I charge them when the initial charge runs out?
Thanks.
Hi @Rhino3957 and welcome to the Community
You need a USB Type-C cable to charge the headset.
You can use it with a USB AC adaptor or a PC for charging.
Here are the charging instructions.
