Is there a remote compatible with the Sony MEX N4300 BT?
hello @VHarani
if you download Sony Music Center app on google play or apps store. you can use your smartphone to control device by touch inputs or by voice.
https://www.sony.co.uk/electronics/support/mobile-cd-players-digital-media-players-mex-series/mex-n4...
Thanks but I've just checked again & can see it comes with the Sony RM-X231 remote in some markets.
Can you confirm if that remote would be compatible.
