Hi, I've just ordered the new Nwa306 from the UK Sony store but have been reading up on the negative comments regarding the volume restricted settings and power output on the UK model. Can anyone advise how I can purchase one directly from Japan safely. Not too concerned about paying the extra for import taxes as long as it's not silly. I've currently got the NWA 105 Japanese version which is great apart from the battery life.
Regards Graham
hello @gajones2663
have you tried to visit https://www.sony.jp/
if you are using google chrome you can use the translate feature to understand the webpage.
