Hi there, could anyone please tell me which Walkmans support on device playlist creation / editing?
I have previously used Creative Zen devices and similar that support the creation of playlists on the device (from tracks that are on the device).
Is there a Walkman device that can do this as it's a reallyuseful feature and I'd like to buy Sony.
Help much appreciated
Thanks
Sony don't support " On-the-fly" playlists You have to either use WMP or Sony's own MediaGo software and transfer it to the walkman. It would be a good feature for Sony to incorporate, though
Hi there - thanks for the reply.
That is a real shame - Creative devices don't have the quality of Sony which is why I'd like to switch, but I'd really miss this functionality: on the Zen device you simply scroll through tracks and press the option button (I guess the Creative equivalent to the right mouse button on a PC) and select add to selected - when you go to the "playing Now" you again hit the options button and save as playlist - it's great when you just want enough tracks to see you through the train journey or whatever...
Any idea when and if Sony might introdcue this?
