nwz-e454 pc connection
profile.country.cs_CZ.title
kontoutaut
Visitor
hi,
i have a little problem with connection with computer, when i connect my walkman, everything seems fine - content transfer shows up and i transfer everything i want, but the problem comes when i want to unplug walkman from pc, i cant unplug it on computer screen, i can just pull usb cabel out of walkman and i think that is not correct solution
on this screen you can see that i cant "safely uplug hardware" because i cant see the connection
http://img15.imageshack.us/img15/988/87431833.jpgthanks for every advice
0 REPLIES 0
