profile.country.bg_BG.title
white_stig
Visitor
nwz-e453 demo
how can i turn off the DEMO mode for nwz-e453
Tags (1)
1 ACCEPTED SOLUTION
Accepted Solutions
profile.country.GB.title
Thalamus.
Champion
Hi white_stig,
welcome to Questions & Answers..:smileyhappy:
Try this.
5 REPLIES 5
Thalamus.
Champion
Hi white_stig,
Try this.
white_stig
Visitor
thank you. it worked and the problem is finally solved
Thalamus.
Champion
Excellent, thanks for the feedback..:smileyhappy:
mimsa_timcheva
Visitor
are there any other options? i tried that couple of times but it just doesn't work!
P.S. could it have something to do wuth the player being a display model?!
Message was edited by: mimsa_timcheva
mimsa_timcheva
Visitor
it worked! But after holding the Home button down i had to turn hold on. Then i did 5 X left 5 X middle and 5 X right and hold off and it happened! Thanks. What you said was very usefull!
