can i connect my mex bt3900u to a peugeot 206 steering wheel controlme
Hi montstpere,
I would say this should be possible using third party accessories. Basically you will need a steering wheel control adapter specific to your car, and then a patch lead that is specific to the make of stereo you are using.
I've used these guys before, and been very happy, but I'd suggest perhaps giving them a call to make absolutely certain on compatibilty before you buy.
Hope you find something that works for your car.:smileyhappy:
Hi montstpere,
