Just purchased this car its a 2010 model with a Sony in car stereo system. Can anyone please give me some help with syncing my phone. I went into the phone menu but cant find an option that gets it to discover new devices. Manual isnt any help either. Thanks in advance to anyone who can assist.
Hi isiri12,
Does the following link help - Ford-mobile-connectivity
Using this link you should be able to select your Ford Focus & then select your Mobile phone make & model.
This should display what options are avaialable to you.
Then if you click on the FAQ link it may help you to connect your mobile via bluetooth.
From memory Bluetooth is already active on the Radio & you need to enable bluetooth on your phone & serach for devices..
Hi isiri12,
Not all Fords have the blue tooth active I have same car but doesn’t have Bluetooth
