Hello. Please help! I have looked online and can't find a case for my walkman!
Does anyone know if there are cases or skin for this serial number? All I can find are different numbers and I want to buy the right one.
Thanks for any help x
Hi Caz111, sorry for the delay in getting back to you on this one. I wanted to be sure of the answer.
Unfortunately, there is not a case or skin for this model in the current range of Walkman accessories.
That’s not to say there isn’t something out there that might do the job, certainly worth looking.
Lee
Lee
Thank you! ill have to buy a sock or something, to keep it safe
best wishes
