profile.country.en_GB.title
CATFISH4U
Visitor
CDX-GT540UI
Hi There
The blue colour of the face is too bright at night, how can it be dimmed, please?
Bruce
1 ACCEPTED SOLUTION
Accepted Solutions
Drumzman
New
Hi Bruce,
I think there's a display dimmer function on this unit - press and hold the 'select' button until the setup display appears - then keeping pressing the select button repeatedly to get to the setting you want to adjust (in this case 'DIM' for the dimmer). Then rotate the volume control to move between dimmer ON and OFF.  Finally press and hold the select button again to exit the setup.
Hope this helps.
1 REPLY 1
Drumzman
New
Hi Bruce,
Hope this helps.
