Partilhe a sua experiência!
VPC-Z21L9E
NB SONY VPCZ21L9E/B.IT1 13.3"LED BLACK I5-2410M 2.3GHZ 4GBDDR3 128SSD W7PRO64 WIFI BT 3G HDMI CAM FP 2USB 2Y
VPC-Z21M9E
NB SONY VPCZ21M9E/B.IT1 13.1"BLACK I5-2410M 2.3GHZ 4DDR3 128SSD W7PRO64 WIFI BT 3G HDMI CAM FP 2USB DOCKING =DVD±RD-VGA/A1GB-LAN
VPC-Z21X9E
NB SONY VPCZ21X9E/B.IT1 13.1"BLACK I7-2620M 2.7GHZ 8DDR3 256SSD W7PRO64 WIFI BT 3G HDMI CAM FP 2USB 2Y
VPC-Z21V9E
NB SONY VPCZ21V9E/B.IT1 13.1"BLACK I7-2620M 2.7GHZ 8DDR3 256SSD W7PRO64 WIFI BT 3G HDMI CAM FP 2USB DOCKING =DVD±RD-VGA/A1GB-LAN
Solucionado! Ir para a Solução.
Model | VAIO VPCZ21V9E |
Processor | Intel® Core™ i7-2620M 2.70GHz (with Turbo Boost up to 3.40GHz) |
OS | Genuine Windows® 7 Professional (64bit) with Service Pack 1 |
Memory | 8GB DDR3 1333Mhz SDRAM |
Drive | 256GB SSD Flash memory (RAID 0) |
Screen | 33.2cm (13.1”) VAIO Display Premium (1600x900) with wide (16:9) aspect ratio |
On-board graphics | Intel® HD Graphics 3000 |
Optical drive | DVD SuperMulti Drive (included with VGP-PRZ20C Power Media Dock™ – see below) |
Others | WLAN 802.11a/b/g/n; 3G WWAN; Bluetooth® 2.1 + EDR; USB 2.0 x1, docking station/USB port x1 (supports USB 2.0/3.0 compatible devices); HDMI™ out (3D supported); stereo speakers with Dolby® Home Theater® v4; HD web camera powered by ‘Exmor’ (1.3 effective megapixels); Web, VAIO and Assist buttons; touchpad with gesture support; fingerprint sensor; Quick Boot |
Dimensions DxHxW | Approx. 210 x 16.65 x 330mm |
Weight | Approx. 1.18kg (with standard internal battery) |
Model | Power Media Dock™ VGP-PRZ20C/VGP-PRZ20A |
Graphics Accelerator | AMD Radeon™ HD 6650M |
Video RAM | 1GB DDR3 |
Max. resolution | Analogue RGB: 1920 x 1200 HDMI™: 1920 x 1080 |
Optical drive | VGP-PRZ20C: DVD SuperMulti Drive VGP-PRZ20A: Blu-ray Disc™ Drive with DVD SuperMulti |
LAN port | 1000BASE-T/100BASE-T/10BASE-T x1 |
USB port | Hi-Speed USB (USB 2.0) Type A Connector x2, SuperSpeed USB (USB 3.0) x1 |
Monitor port | Mini D-Sub 15 pin x1 |
HDMI output port | x1 (3D Supported) |
Dimensions DxHxW | Approx. 148 x 16.65 x 220mm |
Weight | Approx. 0.685kg |
