HELP
I have just brought a XL 302 Will play normal DVDs but when I try to play a blu-ray disc it fails.
Can onyone help please ?
Hi polo11,
welcome to Club Vaio..
Have you installed the two Win DVD BD updates.?
You can download the updates for your Vaio via the Sony support download page, Use the following link to download the update: Sony Support Downloads
H Thalamus,
Thanks for the help I will try.
You're welcome let us know if it helps.?
Hi Thalamus,
Many thanks I have done the updates and perfect !
Is it possible to change DVD region to "B" ?
Kind regards
Polo11
Hi Polo11,
launch Intervideo WinDVD BD for Vaio, then right click on the WinDVD BD for Vaio application window, from the list select Set-Up.
In the new Set-Up window select the Region Tab.
In the region tab select either DVD title or BD title and then select Region you require..
:smileytalk_to_the_hand: Note that you are only able to change the BD region settings 5 times and DVD region settings 4 times, once you reach that total the drive will be permanently fixed to that region...
