Good Morning all, i have a couple of these machines one has a dead MB and the other will not rebuild from the restore disk since updating the BIOS keeps coming up as invalid image file. the disk is fine so that can be eliminated. So also tried a new HD same problem, the only problem is when i flashed the BIOS the .bak file saved to the HD. Me in my enthusiasm to get the thing working (after adding all new fans as well) forgot to save off the .bak BIOS file. Does anyone have any ideas??? i did rebuild the thing with XP but still cannot use all the applications from the original disk? sorry if i've lost you on this....also does anyone know if a new motherboard canbe found for these. Thanks
