Hello everybody,
normally I can use "Wireless switch setting utility" by the icon in system-tray i.e. to change from W-LAN to Bluetooth. Using my notebook (VGN-A517B/XP), the icon is mostly not visible in system-tray after booting and I can't find a connection in start/programs.
Any hints avaliable (file in C.\windows)?
Thanks MaLi
Hi MaLi,
does the wireless switching utility appear if you click on show hidden icons.?
Press Control, Alt and Delete, then select Windows Task manager, select the Process tab, can you see Switcher.exe listed under image name.?
You should be able to manually launch Switcher.exe from within C:\Program Files\Sony\Wireless Switch Setting Utility
Hi Thalamus,
answer: no
answer: yes
answer: thats it! thank you! MaLi
You're welcome..
