I have PCG-K415B, Netopia ADSL router, a desktop PC with wireless card and Toshiba notebook. No problems with sharing the Internet, but I want to set up the 3 computers in wireless network to share files, play games etc. Please advise.
I know that, just when I load the files to the USB Flash it says that I have to input this into every PC and the router. The problem is that there is no USB on it. That's why I need help. Thanx anyway.
Burn the files to a CD then run it from there on the PCs. You shouldn't have to modify the router other than to ensure that DHCP is turned on and that the encryption settings and SSID match those on the PCs
