Model No VGN-A115B. how can I setup wireless internet connection? I subscribe for diap up connection from AOL and they say that they do not support wireles connection. Any engineer who could help?[url=mailto:[email protected]]
If you're going to spend the money necessary to get the kit for a wireless network why not upgrade to broadband at the same time?
If you want to go to wireless 56K modem then the only bit of kit i can think of is the apple airport extreme base station with the built in modem.
But as suggested above you probabuly should go to broadband to make the best use of wireless internet.
What you need to do this is an ADSL/Wireless/Router such as the Belkin ADSL Modem With Built-In 11g Wireless Router
Belkin have a good page on how to set this all up at the below link
http://www.belkin.co.uk/networking/
AOL should be able to give you broadband with wireless information. Or there are many other companies that offer broadband such as BT.
AOL do support a limited range of wireless routers, but here's a link to some other broadband routers known to work with AOL:
http://www.broadbandbuyer.co.uk/BuyersGuide/FAQDetail.asp?TextID=498&SetID=99
