Hi
I am either thick or blind. I am trying to connect my canon camcorder to my K115 to record on to DVD's. The notebook does'nt seem to fit any slots on the K115. Can someone help by pointing out where exactly is IEE port on the K115
Thanks
Is it a big 6pin cable or a 4pin?
It's usually on the left hand side.
Hi yea as stated above the firewire (IEEE) port is on the leftside of the laptop next to the audio ports. The laptop has a 4 pin connection the same as on your camrea.
If you have a look at the image below the firewire port is the one to the right of the green audio out port.
Hope this helps
You might have to right click on the picture and select show picture
Hope this helps
You might need to right click on the image and select show picture.
Yeah it's wierd, wonder why that keeps happening?
Maybe because of the @ sign?
