hi i have a VGN FZ-21m with vista home premium german i have installed vista home premium english OS now the switch between windows is not working properly and i didnt get the vaio update icon .can any one help me..plz thanQ
Hi yashwanth and welcome.
Have you reinstalled all the Sony Drivers and Utilities?
Unfortunately, you will have to update your Vaio manually. If you have changed from the original Sony OEM operating system, some things like Vaio Update and Vaio Recovery Centre will not work. You will also lose other applications and software.
You can download UPDATES from here: -
http://support.vaio.sony.co.uk/downloads/updates/updates.asp?site=voe_en_GB_cons&c=0&s=VGN-FZ&m=2805
but you cannot download the original software.
