Hello. Recently I installed Windows 8 in my computer. I did a "migration" install, bringing all the files and folders from Windows 7. Now I'm planning to do a clean install instead.
The question is, what Vaio Software can I download (and use) after the clean install? Seeing there are Windows 8 tab in my model's support page (VPCF23L1E/B downloads, http://www.sony-europe.com/support/en/product/VPCF23L1E_B/updates), can I, for example, get my backlit keyboard to work with those downloads after the clean install? Can I get Vaio Control Center to work? At least the control center works currently, and it's the same version I had in Windows 7.
PS: I do have Windows 7 backup in case something goes wrong - I can always revert.
