Why my AntiVir gets deactivated???
Sabi
Visitor
Hi everyone;
I have got AntiVir Version 6 for Windows. Every now and then I have to activate it from ¿Service¿ in "Admin tools" as it goes off automatically! :smileythinking:
Has anyone had this experience before? And knows why this keeps happening?? It is quite frustrating to check if the umbrella is up!!! :angry:
Sabi :slight_frown:
25 REPLIES 25
profile.country.GB.title
rich912
Contributor
I have no experience of AntiVir, but it is well known that some viruses disable your antivirus programme.
For starters I would run a full virus scan whilst in `Safe Mode¿ and follow that up with an Ad/Spyware scan.
Go n-éirí an bóthar leat
profile.country.de_DE.title
seb21__
Visitor
I use AntiVir too. I agree with Rich.
I would download Antivir again.
After this, I would restart the Computer in the Save-mode with network. Activate your Firewall and use this Link:
http://de.trendmicro-europe.com/consumer/products/housecall_launch.php
this is a online virus scanner. You need the IExplorer to use this scan.
Make a complete systemscan and reinstall AntiVir.
rich912
Contributor
And just in case anyone has a problem understanding the German language, this is the same link in English:smileywink:
profile.country.en_GB.title
kee-lo_
Member
What is this program?
Seriously get yourself AVG, it's excellent and it doesn't cost a penny if it's for home use.
seb21__
Visitor
Sabi
Visitor
Thanks for your reply Seb;
I don't know how to restart the computer from safe mode :slight_frown:
If I have to install AntiVir again, I have to uninstall it first, right? How do I protect my PC against viruses while the installation is being processed???:smileyconfused:
Sabi
Visitor
Hi Kee-loo
Which site is the best to get AVG from? I have "Ad-Aware Se" would that clash with it?:smileyconfused:
Sabi
seb21__
Visitor
press F8, after you have seen the VAIO logo.
in the safe mode, windows loads only the most important drivers.
the result is that N O R M A L L Y no virus can start in this mode.
(may be, I'm wrong)
Make a online Virusscan (use the Link from Rich)
I would check the Firewall. (Sygate sycurity scan )
kee-lo_
Member
from their official sitewww.grisoft.com
