Hi al,
Recently, I ran a bit computational work using Matlab in my laptop VGB-B1XP. Then I received a message say, virtual low memory.
Does it meants I need to upgrade my memory module?
I've check the program & it turns out that the program need memory beyond the capability of 32bits machine.
Thanks in advance for any comments...
regards
Bart
If your VAIO becomes horrible slow, then I would upgrade the RAM. Take a look at "CRUCIAL". But you could add more space for Virtual memory.
I'd say when you need more powerful software - then you should consider buying RAM
