Computer blacks out, everything appears to be running but no picture. Have to use normal start button to effect a shut down. Restarts OK and may run mins, hours, or days before it repeats the problem.
Any ideas
Hi pehutchxk
I see that this model has some issues with the screen backlight, if you google "sony VGC-LA3 nvidia" you might find the top result contains opinions and issues with the problem itself.
This may be the part, but I am not 100%, if you search for "sony VGC-LA3 inverter" it may be the replacement.
Auction sites seem to sell this as new for about 30£ so it may be replacable.
Maybe someone has seen a similar issue before?
Hope we can help
binbash
Hi pehutchxk
Do you have any more details on the model of your computer? The display manufacturer/model if it's a desktop. Operating System details etc?
Thanks
binbash
Hi Binbash
It is a Sony VGC-LA3 all-in-one which I bought new in 2008. I am running W7 Professional
Hi pehutchxk
Hope we can help
binbash
Hi binbash
Thank you for help. The symptons quoted in your btwo references apply equally to my computer.
Mine is still tolerable and I will soldier on
Thanks agaian
Hi Peter
No problem, I hope it stays alive until you find a new shiny one to replace it :smileyhappy:.
binbash
