Where can I buy hinges for my vaio VPCEB2MOE PCG-71311M as one of mine has broken
I don't think if this can be purchased anywhere. You can check on your nearest computer store and ask for it. You may not get the right hinges for your Vaio, but you might get almost like it.
garlangreeny,
Thanks for your reply.
I have been on to our local vaio service store, they are to get back to me as soon as they can.
I will let you know how and when they do.
hi do you recovery disc of pcg-71311m, if you have can you give one plz
@ishwor165 Hi and welcome to the Community
If you can't find your recovery discs have you checked if you can buy them Here?
Hi Hamnet - welcome!
Have you looked on eBay?
