Hi, could anyone please help me with a problem i have with my sony vaio laptop, i always just leave the laptop open on my table,but closed the lid the other day and when i opened the lid and booted up the screen colours were all wrong and looked wired? i tapped the back of the screen on the case and it went back to normal, this only happens when i close the lid,but once i tap the back of the screen on a reboot its fine, any ideas please? Thanks
Hi Tony,
This would seem to be a hardware/cabling problem with the screen. If possible try connecting an external monitor either via the VGA or HDMI port to confirm this.
I suggest that you raise a case with Support - assuming that you have managed to confirm that you are still within warranty (referring to your previous thread).
Rich
Hi Tony,
Rich
Thanks for the info, no the warranty run out 4 weeks ago, dont really know what to do now?
Hi Tony,
You could contact one of the authorised Sony repairers for their opinion.
http://www.sony.co.uk/support/en/repair/asc
Rich
Hi, ok i have seen Sony replacement screens for £65.00, i was trying to find out where to find a replacement video cable and parts numbers? could anyone please help with a link etc? Thankyou
Hi Tony,
Contact one of Sony’s authorised repair centers - uncertain as to whether they will 'supply only' but worth trying.
Rich
