Hi, I've had my VAIO 8 months now, and it's having problems playing video (web embedded..windows media player..divX player..anything). What happens is that it zooms into the top left hand corner, so cuts out a fair bit of video. Maybe i'm just being stupid and it's a simple zoom thing.
I've got DivX codecs, all players are fully up to date
I run Windows Live Messenger, Windows OneCare (fully up to date..so no virus's) and Limewire, they shouldn't contribute to my problem, but the windows stuff is mostly BETA, so you never know!
One way to fix it is to Run the same video in two applications simultaneously..and the latter application will display it perfectly
Bizzare. huh?
Any help would be much appreciated, you can contact me via e-mail ([email protected])
Stuart
