Does VGX-TP3E have a Hybrid TV Tuner? If yes, it should work with digital and analog signal?
No - all the TP3 models have a dual digital tuner.
The older TP2S did have a hybrid analogue/digital tuner.
The specifrications of the VGX-TP3E say that it has a double DVB-T digital tuner.
No mention of any analogue tuner.
http://support.vaio.sony.eu/computing/vaio/specifications/index.aspx?m=VGX-TP3E_B&l=en_GB
What about the TP3Z, does this one have Analog tuner? Thx in advance!
