Hi all,
I want to know what are the compatible battery models for VGN-FW31E. Its model is VGP-BPS13/S. IF any one can find.Thanks I would be appriciate it. Thank you in advance.
I would avoid compatible batteries for Sony Vaio's if a were you. You can pick up a used genuine Sony battery that has been tested and working perfectly fine for around £20 - £40.
You can use any battery that starts VGP-BPS13, the S just means that the battery is silver, and if there are any letters after the 13 and before the S, this is just a different powered battery.
Have a search on Ebay for VGP-BPS13 and keep an eye out for genuine Sonyu Vaio batteries.
Message was edited by: -Cass-
Advertising with link to commercial website/personal information irrelevant to the thread
hi you can find it in this online shop http://www.achatbatteries.com/sony-vgp-bps13_s.html for your SONY VGP-BPS13/S
