Hi all... I just dug up an old laptop model number VGN-Z21WN.
I thought I'd upgrade to Windows 8, which I've done. I now find that a few things aren't working properly...
1. Screen Brightness
2. USB Ports not recognising devices plugged into it
3. SD Card slot isn't working
Would anyone happen to know where I can find drivers? I've been to this site and grabbed all of the drivers I can but still having these problems.
Thanks in advance for any help anyone can give.
Cheers.
Thank you for replying!
That's disappointing news.
I believe that I did a clean install.
Like I said... it seems that most aspects of the laptop are working and I've installed most of the drivers that you've given me the link to. But I'm currently not getting the SD card reader to work - and this is one of the drivers on the site that seems to have been updated for new versions of windows.
I'll keep looking I guess. I really don't want to give up on the laptop. It's pretty good right now... just not all there at the moment 😞
