I have update my VGN-NS11M Windows Vista to Windows7 Ultimate.Please help me to install Vaio drivers and motion eye driver.
Hi denizel178,
Unfortunately the link you provided will not open so I am unable to comment on this.
I have no experience of Windows 7 Ultimate but I do know that a number of users experience the same problem when trying to upgrade from Vista Home Premium Edition to Vista Ultimate.
My recommendation would be to restore your system to Vista and then do an in-place upgrade to Windows 7 Home Premium. This should proceed without problem and if necessary the updated Win 7drivers from my previous link should install.
Rich
Hi denizel178,
I assume that this was a clean install as opposed to an in-place upgrade?
You will find updates for Windows 7 drivers and Utilities here:
http://support.vaio.sony.eu/computing/vaio/downloads/updates/index.aspx?l=en_GB&m=VGN-NS11M_S&os=10
If there are no drivers listed in the Update section then install the equivalent Vista driver.
There is no Sony driver for the Motion Eye as this uses a native Windows driver.
If you are having problems installing any of the drivers that I have linked to it may possibly be that you have installed Windows7 Ultimate as opposed to Home Premium.
Rich
Hello Rich,
Thank you very much for your answer. Already I have tried to install Windows 7 drivers , which you mentioned on top link. But unfortunately I have Windows 7 ULTIMATE, not Windows 7.
Where you mentioned,the most of the drivers not stisfied for Windows 7 Ultimate.there are drivers only for Windows7
Even I have checked sony USA, there are drivers seperately drivers for windows7 and Windows 7 Ultimate.
Please check below link here & you will see what I mean
http://http://esupport.sony.com/US/perl/select-system.pl?PRODTYPE=24&NAVDISP=pc
Unfortumately there no drivers for model VGN-NS11M/S.
What's you suggestion ??? to clean Windows 7 Ultimate or what to do???
What the differens between Windows7 & Windows7 Ultimate.
Hi denizel178,
Rich
Hello Rich ,
Thanks for your suggestion.Could you please help me, where I can get Windows 7 Home Premium.Unfortunately I don't have such type of Windows 7.
Hi denizel78,
Try here:
http://www.pcworld.co.uk/gbuk/microsoft-windows-7-home-premium-03351305-pdt.html
Or here:
http://emea.microsoftstore.com/UK/en-GB/Microsoft/Windows/Windows-7
Or Google for a better deal.
Rich
