... can I add more memory to the VGC-LV1S computer .... ??? It comes with 4 GB of memory but due to the work I do on it I need more memory ... does anybody knows if I could ADD more !? THANK YOU ...
Sorry bonieboy - the specifications for this model say the maximum memory usable is 4GB
http://support.vaio.sony.eu/computing/vaio/specifications/index.aspx?m=VGC-LV1S&l=en_GB
