VGC-LT2S screen brightness
Paublo
Visitor
Hi, wonder ig anyone can help, stupid I know but just bought a Sony Desktop VGC-LT2S and the screen seems really bright, recently went onto a paint shop website and alot of the whiteish colours I could hardly make out, I thought this would be factory set but does anyone know if you can adjust the brightness...i've tried screen resolution in display settings but doesn't help
Thanks
Paul
1 REPLY 1
Ciolman
Visitor
Hi Paul,
Did you try (Fn+F5) on your keyboard ?
In addition, you should go in the configuration panel, then in the NVidia configuration panel and decrease the luminosity level.
Hope this help :wink:
