VPCF23N1E -OS Windows 7 Home premium service pack 1
When I launch VaioCare I am getting the message "VAIOshell has stopped tworking.
I am unable to find a solution.
hep to resolve this problem will be much appreciated.
Thanks
Hi redwards48,
This is reminiscent of a problem that many experienced a few years back. For some an update solved the problem but for others it was necessary to uninstall Vaio Care using Control Panel - Programs and features and then reinstall the original version.
http://www.sony.co.uk/support/en/content/cnt-dwnl/prd-comp/SOAVCA_00255379_0042__5952/VPCF23N1E
Rich
Hi redwards48,
Rich
Thanks. Much appreciated you help
