Hi guys,
i have vaio VPCEH1M1. I have a problem with my 3.5mm jack. When i plug headset or my 5+1 hometheater I hear annoying sound... something like 'zzzzzzzzz'
Idk how to explain this... I try everything but I think this will be a hardware problem :S
Any suggestions?
To be sure it's a hardware problem I suggest you restore your PC to its factory settings.
If it does not solve you can try to replace the component here:
https://it.eetgroup.com/Guide/m/Sony-VAIO-VPC-models-VPCEH1M1E-B
Manolo
The first one is "the original" replacement, the second adapter is a "replacement of replacement".
The answer is maybe the price.
For example, I'm out of mind for Sony and I will buying the original one... But is only my "crazy opinion" :smileywink:.
Manolo
