Hello all,
I need your help and advice: I have a PC model VGX-TP1E and wish to swap the HDD with a SSD.
My frien who tried to open the case stopped as he was not sure how to continue. he told me that he removed the bottom case and unscrewed some screws and reached a metal plate he didn't know how to take out.
Has any of you an idea how this could be done, mabe a picture?
Many thanks in advance,
Waiting for your advice,
IONUT
I can this only (Private Sony document, "Confidential", but is online):
http://www.vetus-shop.com/files/Disassembly.pdf
Manolo
Manolo
More than I was hoping for.!!
Muchas gracias Manolo !
Don't warry, it was a plasur, but I'm italian...
Manolo
