Hopefully someone can help, my Sony Vaio laptop has recently started having a scrolling issue. Every now and again, it will constantly start scrolling upwards. This happens on web pages, excel and word docs - pretty much anything that you can scroll up an down on.
I have run a key checker to make sure there arent any keys stuck down that could cause this. I have also checked for updates for my touch pad (there aren't any), but have had no luck. I also tried pluggin in a mouse rather than using the touch pad but it still does the same thing, and also I tried to disable the touch pad, but alas no luck.
If anyone has any ideas - it would be a great help!
thanks,
