Hello,
I would like to restore my vaio to my original settings/vaio software, but i changed my harddisk and i do not have any recovery disks. What should i do? Is there any Vaio software thet reinstals them?
Hi icefellwood,
If you failed to create recovery media when your original hard drive was working your only option now, if you require the preinstalled Sony software which is not downloadable, is to purchase a set of recovery disks from support. The approximate cost is £50.
Rich
Hi icefellwood,
Rich
